Grounded open delta PTs
Do anybody knows - what is grounded open delta connection of PTs, and what for is provided ?
RE: Grounded open delta PTs
My question was - corner grounded open delta what for is provided ? what kind of protection is connected there ?
Almost all voltage related functions, except for directional elements and functions relying on neutral voltage displacement.
Read the thread linked above.
Rafiq Bulsara
http://www.srengineersct.com
The term "open delta" is used for two very different VT configurations.  In the US, it SHOULD mean two voltage transformers connected in delta fashion, but with one phase missing or "open".
However, I have seen the term "open delta" used in this forum by European and UK members to mean three voltage transformers connect in delta but with one corner of the delta left unconnected and used for measurement (typically) of zero sequence voltage.  In the US, this configuration is referred to as "broken delta".
As with any other voltage transformer configuration, grounding is done for safety and to establish a ground reference point.
David Castor
www.cvoes.com
