Torque Requirements for Bolts on Steel Flanges
DANGER (Structural)
Is there a reference for determining the amount of torque required to properly tighten carbon steel and stainless steel bolts and nuts when connecting carbon steel flanges for pipe of various diameters for pipe under pressure? What are the important parameters to be considered?
RE: Torque Requirements for Bolts on Steel Flanges
it is depend on grade of material(material quality) and bolts size
thanks
As a matter of practicallity, what many large engineering firms (the Bechtels and the Fluors) have done is establish standard "torque tables" for various sizes of studs and for variuos types of materials. This table is sent to the piping contractor for his use in piping erection.
The standard tables are typically for "alloy steel" and "carbon steel" studs and machine bolts. Most projects are able to use just A36/A307 material (carbon steel)and A193 B7 (alloy steel) for almost all applications.
The tables are based upon work published by Crane in a valve catalog in the mid 1960s. Flexitalic ( and other gasket manufacturers also published the same information and referenced the Crane source....
See: www.sealsolutions.com/techinfo/
Good Luck!!!
MJC
Friction on the bolt thread can vary immensely due to tolerances, surface finish, corrosion, lubrication etc. Galvanising presents another problem as this is uncontrolled. When using stainless stell cold welding (galling) can occur.
Bolt torque, and flanges and pipe, easy!
"John H Bickford", from memory gives:
Tin = Fp.d.k ((lb.in, NOT! lb.ft) or (N.m)), where Tin = Torque input, Fp = Bolt preload, d = nominal bolt diameter, and k is a fudge factor depending on many variables. The most important of which is the Friction on the bolt/nut threads "which make the bolt work".
The wee calc above, gives an close approximation (10 to 20 percent (%)) to much longer and more detailed calc(s) and methods.
There are many! parametres! to be taken into account. Too many to list here anyway!
Go to the library and ask them for "John H Bickford" title on "Introduction to the design and behavior of bolted joints"
Kind regards
Deezul
The following is an excerpt from a recent edition of The Pressure News (published by ABSA at www.absa.com)
"In general, flange connections consist of mating flanges, gaskets and the bolting elements. Failure to consider
each and every one of these elements when doing up a flange may result in premature failure, leakage,
environmental emissions and even worse, a serious incident. For standard ASME B16.5 flanges, the
standard determines the bolt circle diameter, the number of bolts in the flange and the allowable operating
pressure and temperature. There are also a number of flange face designs (e.g., raised face, flat face, ring joint, etc.) and surface finishes, and gasket designs (e.g., rubber, spiral wound, garlock, or any number of acrylics, Tufline, steel ring, etc.)
It should be noted that each component of a flange has a design parameter or limits that must be
considered whenever a flange is assembled.
- Flange material specification
- Rated allowable operating pressure and temperature.
- Gasket selection required for the flange rating.
- Gasket material suitabilty for the process contained.
- Bolt selection: material compatibility with the flange
material; loading and operating temperature
- Gasket loading for the gasket material and the flange design: torque values. (some owner/user companies may have standards that are different from the gasket supplier).
- Tradesman trained in installation (including bolting up) practice.
- Installation details communicated to the tradesman: gasket rating, material, torque values, etc.
- Checklist to ensure that all the requirements were met."
I was recently involved in a project where excessive torque was used resulting in over-compression of the spiral-wound gaskets. The resulting corrective work wreaked havoc with both the budget and schedule of the entire project, so in my opinion these are all important parameters for consideration when trying to determine bolt torque requirements.
Are you sure that you posted the correct link ?
I tried "www.absa.com" and it got me into some kind of wierd banking seminar, then froze my machine up.....I was creeped out...
The last time I had that kind of creepy feeling was when I dated that one-legged female accountant....back in '82
Another approach is to caclulate the load required on the gasket and use hydraulic tensioners to achieve the load. Then simply tighten the nut up to the flange face with minimum torque. Takes the guess work out of it. I have seen Shell do this on critical service.
Sharing knowledge is a way to immortality
Try http://www.albertaboilers.com/newsletter/v08i1/v8-iss1-net.pdf
jt
shoulda been www.absa.ca
apologies
"What axial tension (e.g. % of SMYS or% of SMTS) should be applied to a B16.5 flange stud bolt when tightening it and what code or reference determines this?"
Table A-2 of B31.3 states allowable design stresses for stud bolts and the usual B7 gets a design stress of 25 ksi. This works out at less than 25% of SMYS (it is actually 20% of SMTS).
Various other codes and references recommend stressing bolts to anything from 33% to 75% of SMYS.
How come none use the value from B31.3 - OK that was two questions but I had to ask!
Dennis Kirk Engineering
www.ozemail.com.au/~denniskb
calculation from :
http://www.cedarhouse.co.uk/
Program name : Bolt Torque
I have calculated the effective stress area using
Deff = Dmaj - 0.9743 / N
which I obtained from several reputable sources.
When I look at some of the tables around I find different effective diameters listed. One of these (Flexitallic) appears to use
Deff = Dmaj - 1.296 / N
Can anyone explain why there is more than one commonly used method and which one is "correct"?
PCC-1 is available in the publications section of the ASME website.
If one knows the desire bolt stress the following site has a download able program that will give different tightening values for a specific flange size, type, and class. The program defaults to a specific value for bolt stress, but this value can be changed.
http://www.welding-units.co.uk/
An interesting note is this program defaults to bolt stress of 50000 PSI. I have some old flange books that use a bolt stress of 25000 PSI. The friction factor can also be changed.
Another site that might be of interest is:
http://www.boltscience.com
This site offers a lot general information on bolted joints and give on a little in site on seat a gasket.
As mentioned above the book by Bickford is very good.
