Electric Car Conversion
With the price of gasoline approaching $4.00 / gallon I am seriously considering converting and old car (VW maybe) into a an electric vehicle to drive back & forth to work, store, pharmacy, etc - maximum of about 50 miles per day.
I am a decent mechanic and know enough about electricity not to kill myself - so this seems a reasonable project.
Has anybody tried this and/or what insights do you have.. Yes - I have found a TON of Net info - but not sure who is telling the truth. One book says you can do it for $300 - that I seriously doubt. But the neighborhood of $3,000 to $4,000 seems doable??
Thanks for any insights or paths to pursue...
RE: Electric Car Conversion
TTFN
Chinese prisoner wins Nobel Peace Prize
ISTR he used about ten, 12V car batteries, mounted pretty much everywhere, and a big DC motor and custom controller, all of which he got for free because it was such a new idea at the time. He painted the car real nice, and put a few tasteful decals on the outside to advertise the battery company. The motor and controller came from the prototype shop of a huge company that was thinking about going into the electric car business, but subsequently didn't.
The big company's name did not appear on the car or any of the parts.
Nowadays, you'd probably have to pay for it all yourself, but on the bright side, motor controllers that should be appropriate have gotten relatively cheap.
I'm guessing that $4k plus the car is do-able. I'd want something with better brakes than a Bug, though. I'm thinking maybe a Subaru would make a decent substrate.
Mike Halloran
Pembroke Pines, FL, USA
Never saw it run, but I'm told it was not all it was cracked up to be. A golf cart might be better would be my editorial comment today.
Rod
http:/
Rod
Next problem is motor and controller.
You'll want at least 30 hp, preferably 50 hp.
Golf carts use a fairly inefficient technology, if you go down that path you'll need more batteries.
Cheers
Greg Locock
I have a friend who converted a VW squareback into an electric car. It had a range of about 65 miles and would top out at about 70 mph, not bad for an all electric car.
His problem with it, was the fact that he lived on top of a hill.
Returning from a trip, if the batteries were down, there was a serious discussion, as to whether, or not, he was going to make the last 1/2 mile up the hill.
B.E.
I read an article in the Ag newspaper "CapitalPress" about a farmer in Haines, Oregon who converted a 1986 Ford F-250 to electric power. The farmer's name is David Anderson and the mechanic who did a lot of the work is Ken Myers. Maximum range is about 50 miles, and max speed is 50 mph. From the article, I think that they kept the four wheel drive, transfer case, transmission and cluth. The conversion cost 13,000 dollars. As an added feature, the truck is also remote controlled at low speed!
Myers also converted a 1965 VW Beetle to an electric drive, and has more than 100,000 miles on it. Anderson can be reached at 541-519-3030. He
Have seen some quite detailed information for DIY conversion of Triumph Spitfires and even some video of one in service somewhere in the US - that would do 70mph (dunno how long for) and seemed pretty quick off the mark too.
There's a bit about one of them here
htt
He used lead acid tech to begin with and definitely had weight issues. He's now gone to lithium tech. He's not saying how much that cost but I'm betting it was alot.
There are some addvantages to starting with old cars (lower weight, simplicity etc) but the old car disadvantages come through as well.
I also watched a lengthy video diary made by a guy in New Zealand who converted a mid 80s Toyota (I think) - that seemed to work pretty well.
You may be able to double you mileage per gas tank with the fuel cells incorporating a reformer.
Reformulating hydrocarbons to hydrogen for use in practical fuel cells is very hard to do on board a vehicle. It also takes about 20% of the calorific value of the HC to do it, not exactly a great help in achieving a mighty leap forward in efficiency.
Cheers
Greg Locock
If I could do that I might go for a Lear Jet for every day of the week, and a Cessna Citation for the hangers on.
Pat
See FAQ731-376: Eng-Tips.com Forum Policies for tips on use of eng-tips by professional engineers &
http://eng-tips.com/market.cfm
for site rules
Essentially what you do is install another 2 stock battery packs, sourced from salvage. So 3 stock battery packs total. Then you install another programmable ECU that piggy-backs on the stock ECU.
This turns the car from a hybrid that mostly runs on gas to a hybrid that runs mostly on electric with about a 50 mile range. When the battery pack runs out then the controller shifts it back to a primarily gas hybrid.
You get the equivalent of about 100 mpg on a cost basis. The plug in charging system is another major component in addition to the extra battery packs and add-on ECU.
this is a total DIY kit, the turn key kits run about $5K to $10K.
This car is pretty high performance when the gas motor kicks in.
Toyota is coming out with a plug in version of the Prius in 2012, IOW this fall. It's the 3rd gen and will go for $25K to $30K.
So you've turned a 50 mpg car into a 60 mpg car for the first 50 miles, by adding batteries. Well done, but old news.
Cheers
Greg Locock
Pat
for site rules
http://sydney.aeva.asn.au/
which is Sydney Australia based. Their website helps but go to a few of their meetings and you'll meet people who have done it and can tell you how to and how much. The guys I met at this particular club were very helpful and willing to share.
This club also has Field Days so you can go for a ride in their cars and if they thought you were serious I think they would let you have a drive as well.
