How Femap works with other solvers (Ansys, Abaqus etc)?
How I can run an analysis with Femap, using other solver than NxNastran?. For example with Ansys solver...
RE: How Femap works with other solvers (Ansys, Abaqus etc)?
Select a different solver when you create the analysis set an go from there. I haven't tried Ansys specifically but I can't see any reason why i shouldn't work
Good Luck
Thomas
See section 8.3.3 in the help manual.
Thanks!
I read that....so I suggest I must install Ansys software to run it.
