Updating models that use forming tools
Hello, I'm wondering if there is a way to have sheet metal parts that have forming tools applied update when the forming tool is modified.  I don't see a way to click on something to make that happen so I've had to delete and reinsert the revised tool.  Am I going about this the wrong way???  Thanks!!
Mechanical Engineer
Field Forensics, Inc.
Engineering isn't about perfect solutions; it's about doing the best you can with limited resources. - Randy Pausch
RE: Updating models that use forming tools
I would expect a rebuild to trigger that action. Do a control Q to force rebuilding.
Hardie "Crashj" Johnson
SW 2011 SP 2.0
HP Pavillion Elite HPE
W7 Pro, Nvidia Quaddro FX580
Thanks Crashj but that doesn't do it.  I'll keep trying!
Mechanical Engineer
It is not possible in Solidworks to update the forming tool and have it roll out to update the part.  This was a frustration of mine for years when I was doing sheet metal parts.
Sorry for the bad news.
This is a limitation of SW.
See Solution Id:S-010925 in the SW Knowledge Base.
Thanks all, bad news indeed.  BTW, does anyone know why I'm not getting email notifications even though I have it turned on?  Good thing I came back in to check on this post!  Thanks.
Mechanical Engineer
Does your name show in the Notify Me box at the upper RH side of the screen?
Is the email shown in My Stuff > My Profile valid?
