Floor Load error in analysis
i recieve this message when running an analysis of my structure
**WARNING** about Floor/OneWay Loads/Weights.
   Please note that depending on the shape of the floor you may
   have to break up the FLOOR/ONEWAY LOAD into multiple commands.
   For details please refer to Technical Reference Manual
   Section 5.32.4 Note 6.
i have refered to the referece manual but still do not understand. any help would be greatly appreciated
thanks
james
RE: Floor Load error in analysis
I know this post is a little old but I have not been on the site in awhile.
This warning will not affect your results but the warning is simply saying that if you have a complex floor it may be in your best interest to split it up into different groups.
Example: If you have a floor that will have an opening; you will need to use multiple groups so the opening will appear and you don't have a floor load with the opening should be.
You will get this warning everytime you use a group in a floor load.
