Failure Modes of a Hydraulic Pressure Compensator?
I'm planning to use an off the shelf pressure compensator (from Sub-Atlantic, Tecnadyne or similar) to bring the pressure in an oil filled cavity 0.5 bar higher than the seawater pressure on the other side of a seal.
Can anyone advise of the likely failure modes of such a spring based pressure compensator?
http://www.nauticexpo.com/prod/sub-atlantic/hydraulic-compensators-for-rovs-27362-213528.html
Cheers
James.
RE: Failure Modes of a Hydraulic Pressure Compensator?
A mere half a bar differential may not be enough to energize some types of seal.
Mike Halloran
Pembroke Pines, FL, USA
