pressure vessel in sump or tank
i need to design a pressure vessel which placed in a sump
what should i do ?
what are the extra forces ?
what should i do ?
RE: pressure vessel in sump or tank
If you attach piping to the vessel nozzles, then the nozzles have to be calculated to include external nozzle loads.
As far as what you should do, take my advice. Go and ask a professional pressure vessel design engineer to designed for you. This way you may remain intact, unhurt and you don't risk killing an inocent person when your pressure vessel might explode.
Best regards,
gr2vessels
