Residential Wood Truss Loading
When loading a residential wood truss to check for capacity do you apply a distributed load in the Y direction over the top members or do you apply joint loads at the member conections.  Also does one use a pin-pin end connection or a pin-roller end connection.
RE: Residential Wood Truss Loading
You apply joint loads at the member connections.  It is pin-roller end connection to allow for lateral movement at the roller end.
You must apply a distributed load in the Y direction over the top and bottom members, to calculate the bending and axial stresses in the wood members for the gravity load condition. For the wind condition you apply the wind uplift distributed normal to the top chords. The reactions should be pin-roller.
Garth Dreger PE - AZ Phoenix area
As EOR's we should take the responsibility to design our structures to support the components we allow in our design per that industry standards.
Woodman88 is correct.  You have to analyze the chords for combined axial and bending.  The way we used to do it, before computers, was to analyze the truss with all pin joints and joint loads, then combine the resulting axial forces with wl^2/10.
hokie66, The formula wl^2/10 is no longer used, since 1991, in the wood formulas. See the current NDS.
