PLS CADD Phase - Phase Clearance Question
I set up the criteria under CRITERIA -> PHASE CLEARANCES...
Now the problem is I'm not sure where to get a report specifically on the phase clearances that I set up under my criteria.
-Ethan
RE: PLS CADD Phase - Phase Clearance Question
I mainly use the Tower and PLS-POLE programs to analyze the structures but know a little about the line design in PLS-CADD.  First, I would say to read the manual and get an idea of where the function is located.  Second, I would call their help line and talk to the experts.
I did fire up the software and loaded a demo line and the menu I think you want is SECTIONS => CLEARANCES => Between Sections... which will bring up a dialog box where you can select the from section and the to section and the weather cases to consider.
HTH
_____________________________________
I have been called "A storehouse of worthless information" many times.
