different part colours in photoworks
Hi Gang,
I can't seem to get my assembly to show the different part colours when doing a photoworks render. Can anyone tell me how to do this?
Gerry Bolda
Gerry Bolda
RE: different part colours in photoworks
Check out the Lure, at my site if your using SW01+. The materials are saved in the file. If you open up some of the parts and pick the features and click Photoworks\Materials you will see what I have choosen for that features as their material.
I hope this helps,
Scott Baugh, CSWP
credence69@REMOVEhotmail.com
http://www.3dmca.com
http://home.insightbb.com/~scott.baugh/
*When in doubt always check the help*
But I still think the materials are worth it to apply. Gives it a better look and understanding if you have the proper materials applied...but to each his own.
Scott Baugh, CSWP
Suggestions?
Crashj 'a colorful character' Johnson
I just saved a jpg using a photoworks and a regular image and they both look great. How did you make yours in Photoworks or a regular jpeg file? Check you settings in Photoworks and "Render Image to file". Then click on options and then on custom and see if the bar is set up in the high quality position. If not pull it up there. You can click OK. Now go back into the option and click on high now.
I know this seems stupid, but I found a bug in this option the other day. I was getting some super nasty 256 colors jpeg files. I found that this option was for some reason saving the Low quality setting in Custom when I specifically asked for High quality and had the high quality checked. So the fix was like I described above.
As for Tiff files you need to see the thread Thread559-21429
At the end I posted and email I got from the Topica SW NG. The whole thread is helpful though.
Let me know if this helps you out or not,
Scott Baugh, CSWP
