Rapid Measure of a leading ede abrasion
Hi
I am searching methods for measure an horizontal stabilizer leading edge made of aluminium 2XXX without doing any test.
I only find a method--> Compare the marks of the abrasion with a correct picture of an aluminium leadinge edge who has been tested in the same abrasion enviroment
RE: Rapid Measure of a leading ede abrasion
NDI will find the thickness of a sheet ... if that's what you're looking for.
gorkabilbao...
We need a better definition of Your problem.
What do You want to do.. and WHY? IE: is there a sudden "screaming" need/urgency due to obvious [FAA, DoD, JAR, etc] airworthiness concerns... or this this an exercise assigned by Your boss?
What thickness, alloy-temper are You inspecting?
What inspection accuracy/tolerance do You need?
What do You intend to use the inspection results for?
Regards, Wil Taylor
Trust - But Verify!
We believe to be true what we prefer to be true.
For those who believe, no proof is required; for those who cannot believe, no proof is possible.
