PE coated steel pipe- What type of method is this?
I have got this pipe sample and can not figure out on which method or process was used for coating it with HDPE?
I went through the 3LPE processes explained in the web and it doesn't seems to be the same process used with this pipe!
the HDPE coating in the picture is like casted not wrapped as in the
3LPE process!
3LPE process!
RE: PE coated steel pipe- What type of method is this?
Let your acquaintances be many, but your advisors one in a thousand' ... Book of Ecclesiasticus
Steve Jones
http://www.linkedin.com/pub/8/83b/b04
Steve Jones
Thank you for contribution...
Best regards...
