High Temp. Electrically Conductive Mold Release Materials
Good Afternoon,
 I am looking for a material that can be purchased prefferably in an aerosol form that is electrically conductive and can withstand high temps. possibly upwards of 2000C to act as a "mold release agent".
 Something similar to NeoLube or Boron Nitride however BN is not electricaly conductive.
  Anyone have any ideas? Best Regards and thanks for the help.
RE: High Temp. Electrically Conductive Mold Release Materials
Graphite powder.
I think thats what Neolube is, colloidal graphite in isopropyl. Im kind of looking for other alternatives. But thank you Compositepro.
May we ask what your are going to inject using what material for the die.  Unless your mold is very small you cannot get near it with an aerosol can.  Electrically conductivity at your stated temperature is going to be hard to do as most material that can withstand this temperature are oxides or fast become oxides.
I would checkout the ACT materials from Matthey.  Advance Technical has some coatings that are capable of 3300 F. You might give them a call to discussion your requirements.  I would also search NASA as they have done a lot of work with these temperatures.  Boric acid can take the temperature but I don't have the physical data.
http://www.advancedtechnicalprod.com/Protective-Coatings.aspx
http://www.noble.matthey.com/
A little more information might help you get better information.
