Smart questions
Smart answers
Smart people
Member Login
Join Eng-Tips now!
Join Eng-Tips
LINK TO THIS FORUM!
Just copy and paste the
code below into your site.
Partner With Us!
Partner Button
(Download This Button Today!)
Feedback
"...Really appreciate your site. Really good site for learning what others do when they run into problems. You guy's are great!!!..."
Geography
Jed057 (Electrical)
10 Apr 11 18:46
Anyone help me,
whatis voltage level to check insulation resistance for anode with cable and earth for cathodic protection.,nomaly this anode for positive ptention from rectifier 50V.
Thank
7anoter4 (Electrical)
6 May 11 10:12
If you intend to test the insulation resistance of the cable you have to be sure the anode end is dry and the connection box end disconnected and then for a rated cable of 600 V [HMWPE] minimum resistance measurer with a tester of 500 V could be 2 megohm .See for instance:
http://www.nexans.us/eservice/US-en_US/fileLibrary/Download_540198890/US/files/Nexans%20Insulation%20Testing%20of%20Low%20Voltage%20Cables%20in%20the%20Field%20-%202010-06-25.pdf
But you don't have to test the IR of the cable. In order to test the cathodic protection system see:
http://efotg.sc.egov.usda.gov//references/public/NE/NE_EFH_650_Cathodic_Protection_Maintenance_Testing_pgs6-34g-k.pdf
The IR test on completed [new] cable in the manufacturer shop will be according to
ANSI/NEMA WC 70-2009/ICEA S-95-658-2009 ch.6.10.2 Insulation Resistance.
Close Box
Join Eng-Tips® Today!
Join Us             Close
