A358 304L Design Temperature
I have an A358 304L Class 1 pipe I would like to have a design temperature in of 880F. It is a vent pipe going to atmosphere passing steam at around 37000lb/hr.
ASME B31.1 Table A-3 stops the entries for Maximum Allowable Stress Values in Tension at 800F. Is it code compliant to have a design temperature above this value?
The design pressure is very low so the MAWP still passes if I interpolate the stress past 800F.
Thanks in advance for your help.
RE: A358 304L Design Temperature
For the record, Note e) for table A-3 states no materials shall be used at design temperatures above those for which allowable stress values are given.
Let your acquaintances be many, but your advisors one in a thousand' ... Book of Ecclesiasticus
