Smart questions
Smart answers
Smart people
Member Login
Join Eng-Tips now!
Join Eng-Tips
LINK TO THIS FORUM!
Just copy and paste the
code below into your site.
Partner With Us!
Partner Button
(Download This Button Today!)
Feedback
"...The forum looks great! You guys have done a fantastic job on arranging things there...Your site is very precise and fun to visit..."
Geography
Use HEC-HMS to simulate two connected reservoirs (storages)Helpful Member!
guanxt (Civil/Environmental)
8 Apr 11 16:14
Please help. I can't find the place to setup two reservoirs connected to each other. They have different stages after the storm event and finally will reach the same water surface level due to the connections.
I tried to use one as the other's downstream storage, but there is no back flow from the downstage reservoir to upstream even the water surface elevation in downstream is higher.
Any thoughts?
Thank you so much!
Helpful Member!  gbam (Civil/Environmental)
8 Apr 11 17:41
As far as I know HMS as well as HEC1 will not perform the task you are trying to analyze.  You may need to find a more suitable software package like Inter Connected Pond Routing (ICPR).  It is the reversed flow that cannot be analyzed in HMS/HEC1.
Close Box
Join Eng-Tips® Today!
Join Us             Close
