3D Centerline in drawing
Im getting 3d centerlines far away outside two different drawings. I dont know where they come from and why they are there. Both drawings got long pipes. I would not have noticed them if i didnt zoom out very much. It seems nothing happens when i remove them but i kind of wonder why they show up in first place.
Does NX add centerlines by itself?
RE: 3D Centerline in drawing
Preferences -> View -> General
...and there's an option titled 'Centerlines'. If this is toggled ON then when you place a Drawing view the system will attempt to create any 2D or 3D centerlines in the view that it can. Now toggling this OFF before manually placing your Drawing views will prevent them from being created. However, if you're using a Drawing template you will need to open the master template file and edit each of the views toggling this option OFF if you do NOT want this automatic creation behavior in the future when creating a Drawing using the templates.
John R. Baker, P.E.
Product 'Evangelist'
Product Design Solutions
Siemens PLM Software Inc.
Industry Sector
Cypress, CA
http://www.siemens.com/plm
Sometimes, while updating the drawing these centerlines appear either exactly aligned to the sheet boundary or outside the sheet boundary , so you can not make them out until you switch off pattern and take the hard copy printout.
One workaround that I use to get rid of them is, close the file without saving and reopen and update all the drawing sheets. Sometimes re-updating the Up to Date drawing also helps.
Deleting them does not harm in any way (if you are fortunate :)), but careful observation of the drawing tells that these are not accidentally created centerlines! In other words these have been moved away from existing view/views.
I mean to say, if you have older version of the drawing file, compare it with the new one, you can find out from which view/views (in the new version) these center lines are missing. Worst thing that can happen is, if you had given dimensions to these center lines, the dimensions will become out of date once you delete the centerlines.
