Source for NaOH/KMnO4 pickling
The punchline is that these are 20' long tubes.
They range in diameter from 1/2" to 4".
This is a 6% Mo stainless.
It is the IDs that we care about.
I have the facility and know how, but I don't have the permits.
I would prefer the upper mid-west (we are based near Milwaukee)but I am open.
Advice and suggestions please.
ed
ed
Plymouth Tube
RE: Source for NaOH/KMnO4 pickling
My first thoughts are other producers/processors like Eagle Stainless Tube, Associated Tube Canada (ATC) or USA (ATU), or Swagelok. Does Cartech or AL have a "lab" tank that can handle these sizes?
shut them down and converted to other uses. It appears that the
jet engine overhaul business has the largest vats available.
You might want to check with some of the chemical cleaning
supplier that supply the material for a customer list with your
requirements. Also you might check the Carus Co to if they can
help you.
Here is a link to Ardox Cleaners. At one time we used a good number of them for some pretty tough cleaning job.
http:/
http://
Here is a machine that use to made in the US which might work if you you can use a little less aggressive cleaner like the Phosphoric Acid Type.
http://www.titech.se/pdf/Niagara_produktblad.pdf
