Color printing problem
Not a modeling question, more a software bug question.
I'm printing to Adobe PDF (via Adobe Acrobat Standard v8) and quite recently HydroCAD has stopped printing in color. I do this:
Print>
Printer Settings>
Select Adobe PDF from my dropdown, then click Properties>
Paper/Quality tab>
...and under "Color" it has the "Black and White" box picked.
So I pick the "Color" box instead>
Okay>
Okay>
Now I should be printing in color. I go:
Print>
Report>
Print>
...and the Print Setup box pops up again. I check Properties and the Color box is still picked, like it should be. I hit "OK."
...and the report prints in black and white instead of color. Then if I go back and check my printer settings, they've been reset to black and white instead of color, even though I didn't reset them.
Weird huh? Any ideas? The behavior is fairly recent, probably within the last month.
Print>
Printer Settings>
Paper/Quality tab>
Okay>
Okay>
Print>
Report>
Print>
Hydrology, Drainage Analysis, Flood Studies, and Complex Stormwater Litigation for Atlanta and the South East - http://www.campbellcivil.com
RE: Color printing problem
Changing the settings for each print job should work, but I've found that Acrobat often ignores these settings and goes back to the defaults.
FYI, HydroCAD doesn't change the printer settings in any way. It uses the existing settings as-is.
Peter Smart
HydroCAD Software
www.hydrocad.net
First check the obvious...
Mike McCann
MMC Engineering
Motto: KISS
Motivation: Don't ask
I checked the windows defaults before I posted actually, Peter, and the windows defaults are still "color," and when I create PDFs out of other softwares (without changing the defaults) they come out in color. This is an issue unique to HydroCAD.
Sounds like you might be out of ideas, and if so no sweat, I'll just keep fishing around on my end. I was mostly hoping you'd heard of this happening before.
