sleeve bearing for use on shaft diameter
hello - i have a condition where a shaft is placed in a bore that contains a bearing - the assembly of the bearing in the bore is some what difficult to accomplish for our overseas manufacturing facility - the bearing now is a bronze sleeve bearing press fit into a housing - has anyone used a sleeve bearing that is a composite material like a du bushing (non lube)that would be pressed on the shaft as opposed to pressing it in a bore - or anyother non lube material that could be pressed on the shaft - melonite coatings or anything like that is simply out of the question due to cost & availabilty overseas - any help or suggestions would be greatly appreciated - thank you
RE: sleeve bearing for use on shaft diameter
is the shaft motion rotation, axial sliding, oscillation? How many other bearings on the shaft?
