two solid works questions
Hi
I have large surface , how to divide it to component and how to add thickness to it
I have solid wworks 2010 premium
best regards
RE: two solid works questions
I'm not sure what you mean by divide component, but look in the help for Split Line.  To thicken the surface (depending on your geometry) go to Insert/ Boss/ Thicken.
Dan
www.eltronresearch.com
Dan's Blog
Depending on what you are actually trying to do, you may have to thicken the surface first, then split.
it give unable to thiken this surface , is there any limitationn on add thickness
If you have radi, that are smaller then the amount you want to thicken it will error. try a midplane thicken or opposite direction
StrykerTECH Engineering Staff
Milwaukee, WI
http://www.stryker-tech.com/
i HAVE STL FILE i IMPORTED THAT CONTAINS THE SURFACE (consists of small triangles ) , I will try the other types of thickness
I doubt you will be able to do much of any use with an STL file.
STL Files << Worthless for anything but directly dumping to rapid protoyping machines.
