UG_CONVERT_PART Syntax
Trying to convert a file from in to mm. Don't have any experience working in command prompt so the syntax is causing me some trouble. I can get the conversion to work if I place my part file in the UGII folder (so that it is in the same directory as UG_CONVERT_PART), open command prompt, and input >ug_convert_part -mm test_part.prt
if I have "Test_part.prt" in a folder on the C: drive that is different than the folder housing UG_convert_part I can't get program to find it. I keep getting the message "Too many files specified". I am trying a syntax like this:
>ug_convert_part -mm -s -d /New Folder/test_part.prt
Anyone see what I'm doing wrong?
Thanks in advance for any assistance.
RE: UG_CONVERT_PART Syntax
So as to save you a lot of digging, here is the single most useful piece of material (see attached) that you would have found at the link supplied above.
John R. Baker, P.E.
Product 'Evangelist'
Product Design Solutions
Siemens PLM Software Inc.
Industry Sector
Cypress, CA
http://www.siemens.com/plm
Whenever you are executing commands from Command Prompt you can get the help by just entering the command name without any parameters, here you can enter this line in the command prompt %UGII_ROOT_DIR%\ug_convert_part.exe and hit Enter, that lists the Help information.
For regular DOS commands you can get help by entering command name followed by /? or Help followed by the command name. For example :
Help DIR
or
DIR /?
Thanks for the help everyone. I got it working and then got it working from the right-click menu in Windows Explorer thanks to the great Power Point from cowski via John Baker.
One small issue that is puzzling me: files that are located on the desktop do not work.
When I right-click on a file on the desktop and choose the convert command that I have added to that menu the Command Prompt opens and after a decent amount of time I get an error message saying that it could not find the directory (can't remember exact wording of the error and am at home now so can't check). If I take this same file and place it in any other directory, either on my local drive or on a network drive, it works just fine: I right-click on the file, choose the convert command, and it executes within a few seconds.
What makes the Desktop different?
Also, we are currently using 4 different versions of NX ranging from NX2-NX7.5. I assume that if I run a part from an earlier version through the converter utility in the NX7.5 UGII folder it will also update that part and prevent it from being opened in earlier versions of NX. Is this correct?
Thanks again for the help getting this working.
The issue with using the Desktop is that the folder name (C:\Documents and Settings\*yourname*\Desktop)contains spaces. Wrap the folder and filename in quotes ("C:\Documents and Settings\*yourname*\Desktop\Wrong_Units.prt") and it should work.
With the batch file approach, try using "%1".
NX 6.0.5.3 (NX 8 Beta)
Windows XP32
The other problem with files on the desktop is the full file name may exceed the maximum length for the full file name in the ug_convert_part program.
Ben Loosli
