AutoGEM trying to delete edges associated with fastener
I am currently trying to model a square vacuum chamber that is constructed out of a square tubular frame with plates bolted to the sides. I am using screw fasteners to attach the plates and the frame in mechanica, but when I start AutoGEM it immediately fails with the error
--The requested operation failed because it results in
the deletion of the highlighted entity. This entity is
associated to a fastener which cannot be deleted.
Source: AutoGEM--
The highlighted entity is the end edge of one of the screw fasteners. I have not been using Mechanica for very long so any suggestions would be appreciated.
Source: AutoGEM--
RE: AutoGEM trying to delete edges associated with fastener
Steve
Stephen Seymour, PE
Seymour Engineering & Consulting Group
www.seymourecg.com
