NX7.5 Sketch -Curve from Curves - Pattern Curve
I was wondering if there was a way to create a linear pattern that would be offset in the X-direction evenly but in the y-direction it would grow incrementally. I want to copy the curves 4 times in the X-direction (pitch = 0.5) but have it move in the Y-direction (n+.25)resulting in 5 sets of curves. I tried the clocking the pattern points (create inffered constrants turned off) but I was unable to set them indivdually (I wanted to clock each one in the Y direction).
Example:
X=0.5 (PITCH) count of 5
X1= 0.0  X2=0.5   X3=1    X4=1.5   X5=2
Y=n+0.25 (pitch) count of 1 (I only want one row)
Y1= 0.0  Y2=0.25   Y3=0.5    Y4=0.75   Y5=1
This seems like it should be simple task maybe I'm just missing something. Any help is appreciated
RE: NX7.5 Sketch -Curve from Curves - Pattern Curve
Try this (example file below is based on this workflow):
Create your vertical Line with the start at 0,0,0.  Now create a smart Point at X=0.50, Y=0.25, Z=0.00.  Now open the 'Instance Geometry' function and using the Type 'From/To' select the Line and then select the Datum Point of the Datum CSYS as your 'From Location' and the smart Point you created as the 'To Location'.  Now enter 4 as your number of copies and hit OK.  Done.
Now once you have this you can edit the X and Y increments by editing the X and Y values of the smart Point.  And you can edit the number of copies by editing the Instance Geometry feature.
John R. Baker, P.E.
Product 'Evangelist'
Product Design Solutions
Siemens PLM Software Inc.
Industry Sector
Cypress, CA
http://www.siemens.com/plm
