Peforated Baffles
Peforated Baffles
I'm working on the project enhancing the disinfection (chlorination) basin. and and looking for any company manufacturing custom-made plastic perforated baffles, which can be easily installed.
Any helpful information will be appreciated.
Thanks.
Thanks.
RE: Peforated Baffles
http://www.cl2s.com/diffusers.html
Thanks anyway.
http
http://www.environeticsinc.com/FloatingBaffle.htm
h
I contacted Environetics inc. and they manufactures custom made baffle curtains.
I have one more question of which I want hear more objective opinion (other than the company).
How long do these baffle curtains last? (compared to the longevity of plastic baffle walls)
Do anybody know the company manufacturing plastic (solid type) baffle walls?
Thanks bimr again for your help.
Another very worrisome case is filling the basin. If the operators turn loose a slug of water into an empty basin, there's no way to avoid unbalanced forces on the baffles.
I've designed several of these systems. I armor (using block or concrete) all turns and entrances for 30 ft. or so. I run the flexible baffle material between these hardened walls. I also add a six inch concrete curb at the base to mitigate some of the filling forces. And if possible, I make sure there's gaps at the base and edges to relieve some of the pressures.
