Check in / check out
i'm struggling to find the check in/out command button in NX7.5. Tried the command finder but i only get File - utilities - List check out parts and check-out modified parts.
In NX 4 there was a NX manager menu with the lock/unlock tool.
Is this still available in NX7.5 in combination with TC8.3, or do i need to go into TC to lock and unlock parts?
Thanks in advance.
Best regards,
Michaël.
NX4+TC9 /NX7.5.2 + TC8.3
RE: Check in / check out
Right click in the Assembly navigator ?
If the assembly navigator doesn't work, try right clicking in the TC navigator.
Ok, so the Lock/Unlock feature is now in the part navigator, it seems to work.
Is right click on the part then refresh teamcenter information, the same as Refresh lock status in NX4?
thanks
Best regards,
Michaël.
