Detail view SW 2010
Detail view SW 2010
Hi, I'm starting to draw with SW (coming from AutoCAD). and I'm wondering how to deal with detail views.
My problem is as follows. I have a a big part with some small chamfers. So in my drawing I want a big view with no chamfers and a detail view of the corners in wich I could see the chamfers.
As I see, and I need two configurations, one without chamfers for the main view and the other without for detailing. That's fine. Now my problem is that the detail view must be in the same configuration as the main view. So I have chamfers in every view or not chamfers at all.
Am I correct or is there something I'm missing?
RE: Detail view SW 2010
Typically configurations are used when you have families of similar parts... or to show various process changes (sheetmetal flat pattern).
-Dustin
Professional Engineer
Pretty good with SolidWorks
