5kV Termination
5kV Termination
I need to terminate a set of 5kV shielded single conductor cables (500kcmil) at lugs in an MV switch. Can anyone recommend a particular manufacturer's kit. Or, are there any in particular not recommended. It's been awhile since I've had terminations done and if memory serves me correctly the last time the installation contractor really struggled. I think because of lack of know-how rather than the kit itself. Thanks in advance for the help and recommendations.
RE: 5kV Termination
If so check out websites of 3M and Raychem. Web search is great tool too. You can always ask the cable mfr too, for recommendations.
Rafiq Bulsara
http://www.srengineersct.com
RE: 5kV Termination
RE: 5kV Termination
http://www.gvk.com.au/pdf/raychem_hvlv.pdf
Or:
http
"Raychem" was the old co. was later "Tyco" and now is "TE Connectivity".
For motor termination -according to NEMA MG1 Ch. 20 Type II [For model of the type II see:
ht
page 34] you may use the same termination.
For motor NEMA type I [limited space, up to 8 kV]:
http://www.nhelec.com/epd-pdf/mck.pdf
But better it is to contact Raychem as they change the number of the product some time.
RE: 5kV Termination
Thanks.
