Standard for piping assembly fabrication for presurized hydraulics
I have been searching for a standard to use that covers the fabrication of welded pipe assemblies for use in pressurized hydraulic control systems.
The designer of our hydraulic system recommended we follow the requirements of ASME B31.3 but it seams to me that this standard excludes hydraulic systems.
The system will be rated for 5000 psi working pressures and these are the connection piping from the hydraulic power unit to the powered cylinders & motors for a mobile crane application.
Any input is welcome.
RE: Standard for piping assembly fabrication for presurized hydraulics
Let your acquaintances be many, but your advisors one in a thousand' ... Book of Ecclesiasticus
