german din 529 anchors
In the old statics for a steel lattice tower foundation the fellow designated din 529 form "b" 24mm 800mm 4000 kilopond
rated steel anchors (the ones with the "hooks".  I have some 24mm rating 4.6 strength, din 529 "c" (with the fishtail 2 inches across at the tips)500 mm long. the origĂ­nal calculations seem to have a 2x safety factor. how safe am i in using these anchors? the tower sits on a 90 x90 cm 10mm base plate and there are 4 anchors located 7 cm in from each end.
