Leaking Protos Using Established Dimensionals
I'm at a loss with a prototype part I'm developing which should be a relatively simple change. Basically, the proto is an offshoot of an existing part used for two years now with great success.
The part is a rotating knob with various hole sizes drilled along the inner circumference - see the attached graphic. The knob rides on a set of o-rings on each side of the knob which creates a seal for a 20-30 PSI, gas-operated pneumatic device. The holes, depending on the position of the knob, align with the concentrically matching o-rings on each side of the knob and are compressed with a round solid on each side that compresses the assembly with four screws. Grooves are cut around the circumference to allow the screws to pass through the knob and attach to the opposite solid piece and also allow for rotation of the knob. With the prototype knob, we are adding some additional settings, changing the detent grooves (scalloped cuts in the knob) for a softer 'feel', etc.
As part of our functionality tests, we apply pressure in the 20-30 psi range into the unit and attach a pressure gauge to the outlet and check for leaks by shutting of the pressure source and see if the gauge drops in pressure which indicates the gas is escaping. The current knob is a glass-filled nylon part and the new proto is an aluminum piece (which would be clear anodized in it's final form). The o-rings are lubricated and made from 70 duro silicone. The aluminum proto parts leak whereas the nylon does not. I've tried several different lots of the proto parts, checked the dimensionals and surface finish, etc but they all leak at the holes closest to the grooves.
Would a nylon to silicone interface vs the 6061 aluminum be an issue? Do certain elastomers seal better with aluminum?
Any ideas or suggestions?
RE: Leaking Protos Using Established Dimensionals
Yes, I have attempted polishing the mating surface on the aluminum prototype to no avail.
Are certain elastimer materials better at sealing on metal than others?
