stainless 300 series - does it usually come annealed?
When you purchase stainless in the 300 series e.g. round bar or whatever - does it usually come in the annealed condition? I think so... thanks
RE: stainless 300 series - does it usually come annealed?
TTFN
Chinese prisoner wins Nobel Peace Prize
If you ordered A276 grade 304 1" round bar and did not specify that it should come in the annealed condition--> how would it MOST LIKELY arrive. Thanks guys
It forms the legal basis for your purchase contract.
And it points out the information that you the buyer must supply.
Plymouth Tube
If so, I think the simplest answer to your actual question is :
If you don't specify the condition,you will get what's more convenient to your supplier's current delivery posibillities.
Depending on your end use the condition may not be a concern as the hardness is derived from cold work. Depending on the machining operations we work full hard 304L with no problems.
