Tank Collapses and Kills Two
I'm a bit curious in the photos what the pattern of "dimples" in the remaining walls represent. It looks like where the horizontal reinforcing would be. I would expect that there would be bars sticking out, at least a few. Some of the resports said the walls were 40 ft. tall and 12 inches thick, which I suspect is not correct.
If those walls were meant to brace the outside wall, it looks like the connection between them failed (or wasn't there).
RE: Tank Collapses and Kills Two
Steve
Mike McCann
MMC Engineering
Motto: KISS
Motivation: Don't ask
How long was the wall standing and loaded before it failed, and any indication of the fluid height on the wall at the time of failure?
I see what appears to be a grout layer at the end of the wall. and it appears these are CIP, not precast.
Mike McCann
MMC Engineering
Motto: KISS
I suspect that someone is burning calculations as we speak.
Mike McCann
MMC Engineering
Motto: KISS
Photo is attached.
Mike McCann
MMC Engineering
Motto: KISS
Mike Halloran
Pembroke Pines, FL, USA
