Mirror Model without Copying
I will need to mirror a part about a vertical line without copying. Is there a function in solid works to accomplish this?
Thanks in advance...
When was the last time you drove down the highway without seeing a commercial truck hauling goods?
Download nowINTELLIGENT WORK FORUMS
RE: Mirror Model without Copying
then in the 'solid bodies' folder, RMB body to be removed and click 'Delete Body...'
I got up to using mirror feature, deselecting
merge solids. I complete the mirror. What is
"solid bodies" folder?
From the parent file, select the plane or face you want to mirror about. Go to Insert> Mirror Part. This will create a separate file as described above.
-Dustin
Professional Engineer
Pretty good with SolidWorks
