NX6 Resource Bar
NX6 Resource Bar
NX6 Resource Bar
I was playing with some settings, and I screwed up how my resource bar appears.
The resource bar now goes from bottom to the very top of the NX window - previously it went from the bottom of the NX window to below the tool bars.
How can I make my resource bar to only to the bottom of the tool bars?
I have attached an image.
RE: NX6 Resource Bar
NX version ?
Try Preferences - User Interface - Layout - settings - Reset Window position. ( NX6)
You also have some settings for the resource bar in the same tab.
You can also try a different Role and see if that helps.
Thanks for the input Toost, but resetting the window position didn't do it, and toggling between roles and that didn't do it either.
I am on NX6
try the registry:
you can delete HKEY_CURRENT_USER\Software\Unigraphics Solutions\NX\6.0
which will remove all the settings for NX6 or delete
HKEY_CURRENT_USER\Software\Unigraphics Solutions\NX\6.0\Layout
which might contain the specific problem.
Anthony Galante
Senior Support Engineer
NX4.0.4MP10, NX5.0.0->5.0.6, NX6.0.0->NX6.0.5, NX7.0.0->NX7.0.1 & NX7.5.0.32-> NX7.5.2.5, Beta NX8.0.0.15
Select Tools ..... Select Customize ..... Go to Layout Tab ..... Set Docking Priority to Vertical
Changing that setting might help
Yes, that should take care of it.  It also means that messing with the registry, at least in this case, would have had no effect whatsoever.
John R. Baker, P.E.
Product 'Evangelist'
Product Design Solutions
Siemens PLM Software Inc.
Industry Sector
Cypress, CA
http://www.siemens.com/plm
