Metric GD&T
Metric GD&T
Hello everyone,
This is my first post. I hope some of you can shed some light on this. I attached a PDF file of a drawing of 2 boring bar mounting surfaces on a lathe turret. I need to design a special holder to go on one of these surfaces but I'm having trouble interpreting the Metric GD&T. My company does all work in INCH so this is new to me. I can handle doing to the easy conversions for linear dimensions, but I'm having trouble interpreting the hole sizing and tolerance range (and the Japanese characters don't help either!).
I bubbled in RED which ones I need clarification on. There are 3 large bushed holes and several tapped holes. The smaller tapped holes have got to be pipe threads because they are used for coolant (hence the PT designation). The 7 large tapped holes are for regular socket head cap screws. Please help!
RE: Metric GD&T
It means that the tolerance for diameter of hole 24 is: +0.021/-0 in milimeters.
RE: Metric GD&T
Plenty of charts on the web, for instance.
http://w
What is Engineering anyway: FAQ1088-1484: In layman terms, what is "engineering"?
RE: Metric GD&T
"Art without engineering is dreaming; Engineering without art is calculating."
Have you read FAQ731-376: Eng-Tips.com Forum Policies to make the best use of these Forums?
