oil and gas separator pressure drop
hey friends!!
Which is the normal pressure drop in oil and gas separator designed by API 12 J???
RE: oil and gas separator pressure drop
The pressure drop is selected/calculated by the process engineer, is not part of mechanical engineering! Also, the sizing is pert of process engineering followed by the mechanical design of the separator as a pressure vessel. You are asking the wrong forum...
Cheers,
gr2vessels
Cheers,
gr2vessels
