oil and gas separator boudnary condition on CFX
Hey guys, I have been working in a oil- gas separator on CFX. The most difficult part has been the correct selection of the boundaries conditions.
The inlet condition is the less difficult since I have the flow rates in that point, the hardest part are the oil outlet and the gas outlet, because I do not have the mass flow in each outlet, Therefore I have thought about to select an outlet with a estimated pressure, the problem is that the outlet pressure is not know!!!
WHAT SHOULD I USE!!! have someone worked with this kind of problem????
