Restriction Orifice Plate Thickness Calculator
Would anybody happen to have an (Excel based) RO plate thickness calculator ?
(My work's computer was recently upgraded and I've lost the one that I had.)
Thanks.
Thanks.
RE: Restriction Orifice Plate Thickness Calculator
h
If you need a good free down loadable FE/RO calculator
get the DG2floCalLite. It's a great program !
http:
tmin ≥ SQRT [(0.681-0.651*BETA)*deltaP/Y] * pipe ID
where
tmin = min plate thickness [mm]
BETA = ratio of orifice hole diameter to pipe diameter
deltaP = pressure drop [MPa]
Y = plate material yield stress [MPa]
Pipe ID = pipe internal diameter [mm]
much obliged for the formula.
best regards,
danny
