Single Shear Timber Connection.
I'm looking for help in evaluating the strength of a wood peg (dowel) connection in single shear.
I studied an old church building in which the rafter sill plate was attached to the ceiling joists with 1-inch diameter wood pegs.  The pegs failed.  I thought it would be a simple matter to calculate the amount of force required to cause the failure.  I was wrong.  I have found information for steel-doweled connections in single shear and wood pegs in double sheer, but *nothing* that discusses the strength of a wood peg (or dowel) in single shear.
Any help at all is appreciated.
RE: Single Shear Timber Connection.
If you have numbers you're comfortable with for wood pegs in double shear, just divide them by two.
Otherwise I'd imagine its as simple as:
Vn=Fc*A  where Fc is the allowable stress of the HARDwood species in compression perpendicular to grain.
Maybe I'm missing something though..
Are you aware of American Wood Council, Technical Note #12? You may be able to make some assumptions and use this document.
http://www.awc.org/pdf/TR12.pdf
If you know what type of lumber - you may get some values from the appropriate grading agencies??
Try the Timber Frame Engineering Council (TFEC) Tech Bulletin 2009-01 and the  TFEC Standard for Design of Timber Frame Structures and Commentary - (TFEC1-07)
I believe they have values for oak pegs
