Solid Works Data Disappeared
I translated a step file to solid works and inserted into an assembly. As I tried to open the part to inspect, the history and the model was not visible. I have a part file with no model. Any help on this would be appreciated.
RE: Solid Works Data Disappeared
There is nothing to post. Just the file and no model.
Everything is there but the history.
A STEP file does not have a feature history.
Do you have a STEP file or not.
Attach it here so that someone can tell you what is going on. Otherwise it is a shot in the dark to try to figure out.
If you can't attach the step - can you attach a screen shot of what you do see after import?
That is by design for all cad software.
Cheers,
Anna Wood
Xeon W3680, Nvidia Quadro 4000, 12 Gb RAM, WD Velociraptor, Dell U3011 Monitor
SW2011 SP1, Windows 7 x64
http://www.solidmuse.com
http://www.phxswug.com
If the 3D model was missing then, perhaps when you exported it, some step was missed. How big was the STEP file?
TOP
CSWP, BSSE
www.engtran.com www.niswug.org
www.linkedin.com/in/engineeringtransport
"Node news is good news."
