Dimension problem in Abaqus CAE
Hello Everyone,
I am a bit confused about the dimension in abaqus.
My base dimension : Length in micrometer, force in micro newton, stress and modulus of elasticity in Mpa.So if my density is 2 g/cm^3 then what should I put in abaqus? Is it 2E-15? I am very new to abaqus.If anyone please reply it would be greatly appreciated and also would be very helpful for me.Thanks in advance.
RE: Dimension problem in Abaqus CAE
SI
Length: m
Force: N
Mass: kg
Time: s
Stress: Pa (N/m^2)
Energy: J
Density: kg/m^3
SI (mm)
Length: mm
Force: N
Mass: tonne (10^3 kg)
Time: s
Stress: MPa (N/mm^2)
Energy: mJ (10–3 J)
Density: tonne/mm^3
2E-15 kg/(micron)^3.That means in abaqus I need to use 2E-15.Isn't it too small?And for this density I am getting result, but the animation in odb is kind of weired(I think).Any idea?
By animation, do you mean deformation? You might need to go into the Options drop down menu and change the deformation scale.
Options -> Common -> Deformation scale factor -> Uniform (try 5 or 10 times the actual deformation)
