Problem With Pro/Detail Start Part
Hi All,
I had used the Pro/Detail start part which is supposed to be used.
But my Tools>Parameters are not visible in my Detail Drawing which are supposed to be visible when i retrieve my Drawing Format from the correct location.
In the Detail Start part all these parameters are visible.
But in my drawing they are missing(even though i retrieved from the same).
They are visible only in my current session.
I had completed my entire Drawing & now i am facing a problem of correcting this format problem.
Is there any way to retrieve these parameters into my drawing under "default parameters" of pro-detail drawing??
