Clarification on seamless pipe fittings
CAN ANYONE HELP ME WITH THE TRUE DEFINITION OF " SEAMLESS PIPE FITTINGS AS IT RELATES TO LAP JOINT STUB ENDS ?
RE: Clarification on seamless pipe fittings
Seamless fittings means there is no long weld seam used for manufacture. Your question as to how it relates to lap joint stub ends is confusing.
Thank you for your your response, your answer is exactly what I thought. Let me clarify the question as to the lap joint stub ends
If we were to weld the entire lap onto the end of a seamless pipe (essentialy a weld build up on the OD ) would this still the be a seamless fitting ?
Yes.
Nstamp best not to use capitals
Cloa
Thank you for your BRILLIANT input
