Weld-O-Let in 18" SCH 40 pipe
Hello all,
I have a number of small bore pentrations to make in an 18" sch 40 line, I had been planing on using weldolets and socklets depending on size, however I notice sch 40 is not listed in the fitting class of MSS SP-97.
I need the full wall thickness of sch 40 for my service and I really don't want to use repads on such small connections.
I am looking for input as to what direction to go, it seems like I may be able to get schedual 40 Weld-O-lets custom made but I can't believe I am the first one who has had this issue pop up.
Any help and direction from the more experienced would be greatly appreciated.
A question properly stated is a problem half solved.
Always remember, free advice is worth exactly what you pay for it!
http://www.ap-dynamics.ab.ca/
RE: Weld-O-Let in 18" SCH 40 pipe
-TJ Orlowski
When you order provide the following information
- Run size and Schedule (example: 18" Sch 40)
- Branch size and schedule (example: 4" sch 80)
- Item name (Weld-O Let)
- Material (Carbon Steel)
- Code (optional) (example: ASME B31.3)
- Quantity (6 Required)
They (BonnyForge/WFI) are pretty smart and will give you what you need.
Let your acquaintances be many, but your advisors one in a thousand' ... Book of Ecclesiasticus
