Showing wrong dimension in drawing, bug in Solidworks?
I have created a part and see it is showing different dimension in the drawing. I have checked all dimensions, it is all wrong the in the drawing. Why is that? Please check attachments.
http://fil es.enginee ring.com/g etfile.asp x?folder=c 9aec9cf-61 ef-47aa-a6 3d-77208c9 800f6& file=1.JPG
Your file's link is: http://fil es.enginee ring.com/g etfile.asp x?folder=6 d67244a-51 e7-49a7-a7 b7-bacc505 56d0c& file=2.PDF
http://fil
RE: Showing wrong dimension in drawing, bug in Solidworks?
-handleman, CSWP (The new, easy test)
