Rendering settings for initial setup
Hey all,
I just installed UG nx6 & am having problems with the rendering settings. It seems ok for most basic shapes, but as soon as I add a blend, the render fails & it looks like crud. I think the wire frame views looks ok, but as soon as I switch to a shaded view the rendering fails.
Thanks in advance for any & all help,
Ashton
RE: Rendering settings for initial setup
By 'rendering' do you mean 'photo-realistic' or something else?
John R. Baker, P.E.
Product 'Evangelist'
Product Design Solutions
Siemens PLM Software Inc.
Industry Sector
Cypress, CA
http://www.siemens.com/plm
When I switch from wireframe to a shaded view the graphics are all messed up and I don't get a solid model.  Its like the rendering fails and the solid is just a bunch of lines connected together.
Bump
Goto Preferences - Visualization Preferences then Faceting and there you will see Shaded views, with a pull down menu Tolerance try to change it to extra fine and see what happens, normally you will have a fine rendering now.
Best regards,
Michaël.
NX4+TC9 / NX6+TC8Unified / NX7.5 native
Also go to...
View -> Camera -> Edit...
...and push the 'Fit Planes to Extents' buttton in the section fo the dialog titled 'Clipping'.
Also make sure that you using a certified configuration, particularly the graphics card, and that you've installed a certified driver.
John R. Baker, P.E.
Industry Sector
Cypress, CA
