Automatically creates different of gear
I used 2009 version and I know there was a toolbox gear function that I can create gear with just a few clicks by selection module, pitch.........
Now I'm using 2010 and sometimes 2011 version, it seems there is no this function available. Is this gear creating function hidden in somewhere? How can I bring this function again thanks..
RE: Automatically creates different of gear
TOP
CSWP, BSSE
www.engtran.com www.niswug.org
www.linkedin.com/in/engineeringtransport
"Node news is good news."
It is there in 2010 also.
Toolbox> Ansi Inch> Power Transmission> Gears.
I am assuming you have other toolbox libraries... just not gears.
-Dustin
Professional Engineer
Pretty good with SolidWorks
If you configure your toolbox, is the "Power Transmission" folder checked in the "select your hardware" area? Past that, is the gears folder checked?
The options that I have are Helical, Internal Spur, Rack, Spur, Straight Bevel, and Straight Miter.
Colin Fitzpatrick (aka Macduff)
Mechanical Designer
Solidworks 2010 SP 5.0
Dell T5500 XP Pro SP 3 (32-bit)
Xeon CPU 2.53 GHz 3.00 GB of RAM
nVida Quadro 4000 2 GB
3D Connexion-SpaceExplorer
thanks
GearTrax is a great product. I do not have it anymore, but did have it at another company years ago. It makes true involute gears with all the AGMA notes and details. ToolBox merely gives a reasonable representation of a gear.
Forewarned is forearmed. Just look at Popeye!
- - -Updraft
