strange window behaviour in SW x64
I have some VB programs and some VBA programs to help me with my work. They worked fine in SW2009 x32. After I upgraded to SW2009x64 (Windows XP)  they started this annoying behaviour that the window they open goes to the bottom of the windows on my screen and I have to dig for it. Same behaviour in SW2010 x64 on Windows 7. I checked one of Tick's programs and it does the same thing. Has anyone encountered this problem and has a solution? I have SW2009 x64 installed at home on Windows Vista and  don't have this issue.
RE: strange window behaviour in SW x64
I have seen the same behavior exactly as you have stated.  I just learned to use the windows button + tab button and select the macro window.  I am on windows 7, sw2010 x64.
This is a major PIA for us using Win7 64 bit.  I'm not in any hurry to "upgrade" my home XP boxes...
so you trying to say you are running 64-bit application on a 32-bit platform? if so, may i ask why?
ws000 - One can't install and run a 64-bit application on a 32-bit platform.
If you're talking about UserForms, there's some code that fixes this issue.  It works, but almost too well, as the windows become "always on top" and sometimes mask error messages.
http://angelsix.com/cms/forum/viewtopic.php?f=30&t=53
Thanks gopack13 for the link. It needed a little tinkering but I got it running. I had to declare the functions private and remove "Global" in front of const.
CODE
Option Explicit
Private Declare Function SetWindowPos Lib "user32" _
(ByVal hwnd As Long, ByVal hWndInsertAfter As Long, ByVal x As Long, _
ByVal y As Long, ByVal cx As Long, ByVal cy As Long, ByVal wFlags As Long) As Long
Private Declare Function FindWindow Lib "user32" Alias "FindWindowA" _
(ByVal lpClassName As String, ByVal lpWindowName As String) As Long
Dim res As Long
Dim lRet As Long
Const SWP_NOMOVE As Long = 2
Const SWP_NOSIZE As Long = 1
Const FLAGS = SWP_NOMOVE Or SWP_NOSIZE
Const HWND_TOPMOST As Long = -1
Const HWND_NOTOPMOST As Long = -2
and in main() or form_load() in my case, right at the end:
CODE
lRet = FindWindow(vbNullString, UserForm1.Caption)
res = SetWindowPos(lRet, HWND_TOPMOST, 0, 0, 0, 0, FLAGS)
I have had this problem with SW2010 and 2011 on both Vista and 7 x64.
This is sofar my best solution.
Every time i have a messagebox i then have to redo it.
CODE
swApp.SendMsgToUser2 "Bla bla", swMbInformation, swMbOk
UserForm_Layout
CODE
Sub SetTopMost(sCaption As String)
  Const FLAG = SWP_NOSIZE + SWP_NOMOVE
  Dim hWndForm As Long
  On Error Resume Next
  hWndForm = FindWindow(vbNullString, sCaption)           'get the handle of the userform
  Call SetWindowPos(hWndForm, HWND_TOPMOST, 0, 0, 0, 0, FLAG)
End Sub
Sub UnsetTopMost(sCaption As String)
  Call SetWindowPos(hWndForm, HWND_NOTOPMOST, 0, 0, 0, 0, FLAG)
End Sub
and then in the form i add
CODE
Private Sub UserForm_Layout()
  SetTopMost Me.Caption
  UnsetTopMost Me.Caption
End Sub
This is the only way i found to bring the form to front and still not lockup solidworks totally afterwards.
